Could not find set of walls? 06 апр 2021 15:26 #1802
Hello, this issue is both for Internal / External walls ... Why does it give me an error "Could not find a set of walls!" ... There is plenty walls in the projekt :D any tips?
Could not find set of walls? 06 апр 2021 15:43 #1803
Hi!
Can you send me a file and tell me in what view you use the plugin and what you are doing?
Could not find set of walls? 06 апр 2021 16:01 #1804
Hey - it is a rather "heavy file" but a small project :D So i made it as a wetransfer.
we.tl/t-ZhpRMFZ5Xo
If you go to sheet AR 2.10 - Stue plan - 1-20 ... And activate the viewport... Or any plan views for that matter ... I get the error shown below
Could not find set of walls? 06 апр 2021 16:41 #1805
Both of these plugins only work with orthogonal walls. In your file, the building is in the model at an angle.
Unfortunately, the plugin will not be able to process them.
Maybe over time we will be able to foresee the rotation of the conditional north, but now there is no such possibility
Could not find set of walls? 06 апр 2021 16:50 #1806
But if you set it "True north" then it should be considered orthogonal ?
I've testet in another projekt file - where i have no issues. Also in that file the project north and true north is diffrent? But in that there was NO issues :D
Could not find set of walls? 06 апр 2021 16:52 #1807
Apparently you did not understand my English =)
How north is set does not matter. Plugin works with internal coordinate system
Could not find set of walls? 06 апр 2021 17:02 #1810
No No, your english is atleast as good as mine! :)
Ahh i see now... Compared to my other "newer" projects... In this one ive swapped the use of True north and project north ... That is my mistake.
Because in other projekts i have this plug in works perfektly... I will try to rotate it all and swap around ... hopefully it will work in this also, thanks for the help.
Could not find set of walls? 06 апр 2021 17:04 #1812
Now it works perfectly! Thanks for your help.
