网站正在翻译成当前语言,请暂时使用英文版本
API Properties are accessible 16 十 2025 21:35 #3224
Is it possible to use API Properties when creating a formula in the Parametrization module?
My wish would be to use the Mirrored property from a FamilyInstance Class.
rvtdocs.com/2024/20ab2f32-e3ca-8173-aac3-a03e998fd0ab/
API Properties are accessible 17 十 2025 06:49 #3225
Not, it is not possible. If you need some API property - write us and we try to add function for it.
"Mirrorerd" already added
