Please add function exlude Title Block and logo from exporting to dwg 07 二 2024 20:46 #2605
The plugin is amazing but one thing is missing.
When we send to the client a dwg drawing we don't want to show the title block and logo in the dwg file to Protect company copyrights.
Is it possible to do this? It would be handy.
Kind regards,
Robertas
Please add function exlude Title Block and logo from exporting to dwg 08 二 2024 10:49 #2606
No, unfortunately this is not possible. The export is done through the standard Revit print. And when printing, you cannot exclude any parts of the sheet
Please add function exlude Title Block and logo from exporting to dwg 08 二 2024 10:53 #2607
I wrote about printing, but I meant that export to dwg is also done through the standard Revit export. If it is possible to set such settings in the export parameters there, then you can apply these parameters in the plugin as well
