Split rebar plugin 21 二 2023 14:11 #2227
  • Micka
Hi,
is it possible to make overlaps with alternate with split rebar plugin like the image below
Thank you
Split rebar plugin 21 二 2023 20:34 #2228
It's about Revit "Split rebar" plugin?
