网站正在翻译成当前语言,请暂时使用英文版本
Option dimension By Line to dimension wall layers and wall openings 11 九 2025 18:36 #3180
  • skept
It would be really useful for dimension by line to have an option to dimension wall layers as well (not only the edges).
Also, I noticed that the action doesn't dimension wall width when it passes through a door opening. An option for dimensioning wall thickness passing through a door is really useful!
See this clip of a different plugin where they managed to do it:
