BUG MEP clash solver 01 Aug 2021 17:00 #1882
  • Alain
With the MEP clash solver plugin, I have a Bug with the ducts following the X or Y orientation
In my example, I have 2 same perpendicular ducts.
One in the Y direction in the plane and the other X
In the X direction, I still have an error
The duct oriented at 30 ° changes section 300x400 instead of 400x300
BUG MEP clash solver 01 Aug 2021 20:55 #1883
This plugin is in the redesign queue. Many fixes will be made soon. Your comment we will also check
