Rebar and Concrete Drawing Automation in Revit 10 Sep 2025 15:30 #3178
  • Hiki
1. Automatic Rebar Tagging in Sections
A tool that automatically places tags for visible rebars in section or detail views. The tool could:
-Detect and tag only visible rebars (based on view range and visibility),
-Display type, diameter, spacing, and quantity,
-Avoid overlapping tags,
-Allow basic customization (leader type, tag offset, tag family, etc.).
2. Automatic Section Dimensioning for Beams
A tool for adding automatic dimensions in beam cross-sections:
-Detects overall concrete dimensions (width, height),
-Dimensions concrete covers to rebars,
-Dimensions stirrup spacing and positions of longitudinal bars (if visible),
-Applies pre-defined dimension styles.
3. Automated Drawing Creation for Concrete Elements
A powerful tool to generate standard drawings for basic concrete elements:
- Supported elements: Walls, slabs, beams, columns,
- Automatically generates: Plan, section, 3D view, rebar schedule,
- Places views on a pre-defined sheet layout,
- Applies view templates, tags rebars, dimensions automatically,
- Supports batch processing (for multiple elements at once).
4. Automatic Rebar Schedule Export (PDF/Word)
An export tool that allows users to:
- Export selected rebar schedules to PDF or Word format,
- Choose which "Partitions" (from rebar parameters) are included in the schedule,
-Optionally combine partitions or separate them into individual files,
-Apply templates to match office standards (logo, table style, title block, etc.),
-Save to project folder with structured naming (e.g. Rebar_Schedule_B1_Walls.pdf).
Thank you for all your work on ModPlus – it’s an excellent plugin suite that’s already helping many of us work smarter in Revit. I hope you find these ideas useful and worth considering for future development.
Best regards,
Stefan Hristov
Rebar and Concrete Drawing Automation in Revit 11 Sep 2025 09:18 #3179
Regarding the first two points - have you looked at the "Section annotations" plugin? It is just for creating dimensions and tags on sections. We are currently working on it, improving it.
We will write down the remaining points in our task book
