ModPlus crashing Revit Architecture 2015 16 May 2018 15:42 #918
Hi
I have windows 7 sp1 running Revit Architecture 2015 & Modplus 10.05.2018 installer.
Revit crashes with this error below.
When i remove ModPlus.addin revit loads with no problem.
From the revit journal file
' 0:< Managed exception occurred:
'C 16-May-2018 22:30:14.263; 0:< Could not load file or assembly 'GongSolutions.Wpf.DragDrop, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
'C 16-May-2018 22:30:14.263; 0:< ExceptionCode=0xe0434352 ExceptionFlags=0x00000001 ExceptionAddress=000007FEFD6F9E5D
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 7325 / 12278 428=InUse 428=Peak
' 0:< VM Statistics: 8386904 / 8388607 348=InUse 350=Peak
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 0:< ::1:: Delta VM: Avail -22 -> 8386882 MB, Used +9 -> 358 MB, Peak +7 -> 358 MB; RAM: Avail -29 -> 7296 MB, Used +12 -> 440 MB, Peak +12 -> 440 MB
'E 16-May-2018 22:30:16.738; 0:<
Jrn.AddInEvent "AddInJournaling" , "MessageBox(OK,Revit).Click(Cancel)"
'H 16-May-2018 22:30:16.746; 0:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 16-May-2018 22:30:16.747; 0:< program terminated
Could you please have a look.
Thanks
ModPlus crashing Revit Architecture 2015 18 May 2018 11:53 #921
Check in the folder /ModPlus/Extensions presence of the following files:
Also check that the properties of these files do not have a lock - blogs.msdn.microsoft.com/delay/p/unblockingdownloadedfile/
ModPlus crashing Revit Architecture 2015 20 May 2018 16:10 #923
All those files are in the folder and none of them are blocked by windows.
I also reinstalled net framework and it still did not work.
I tried gong-wpf-dragdrop.1.2.0-alpha0057 and it also did not work.
Any other suggestions?
Thanks
ModPlus crashing Revit Architecture 2015 21 May 2018 20:55 #925
Do you have any other installed plugins? Try without them.
Also try to start Revit without connecting the functions, but with the plug-in connected. Those. Open the Configurator and turn off all functions
The following user(s) said Thank You: pjackson7575
ModPlus crashing Revit Architecture 2015 22 May 2018 16:36 #927
Thanks for your help.
It was an old plugin left over from an uninstall, once I removed it no more errors.
