网站正在翻译成当前语言,请暂时使用英文版本
Place views on sheets 16 五 2018 16:28 #919
Hi
I have an idea for a revit tool.
You create a new sheet which has the title block, level floor plan, schedule & legend all on the sheet which becomes the template.
Then you select this template & then choose all the remaining level floor plans and then new sheets will be created.
All the new sheets will be placed in the same origin position as the template regardless of the varying crop view sizes & positions.
Then the built-in sheet name parameter on the title block gets it''s name from the view name.
Also the viewport title positions to be placed in the same position.
Then maybe a way to manage all these viewport settings once they are already on sheets if you want to make more changes.
Thanks
PJ
Place views on sheets 18 五 2018 11:48 #920
Have you try Sheet Copy? modplus.org/en/help/mprsheetcopy
It seems to me that this plugin does almost the same thing that you offer. Well, or I did not quite understand correctly
Place views on sheets 20 五 2018 16:59 #924
I did see the sheet copy tool. It duplicates sheets with or without views.
What I was trying to say is place all floor plan views on new sheets in the same position.
Place views on sheets 21 五 2018 20:58 #926
I roughly understand your idea, but I'm not sure that this function is worth the time it took. By the way, the title of the viewports can not be moved programmatically (at least in 2015-2017 Revit)
The following user(s) said Thank You: pjackson7575
Place views on sheets 22 五 2018 17:47 #928
That's ok, no problem.
This was the page I was reading about views & sheets.
forum.dynamobim.com/t/excel-create-sheet...place-on-sheets/5307
Your dimension tools, very useful.
I thought this was interesting
forum.dynamobim.com/t/quickly-dimensions...rent-categories/9375
The script dimensions columns to the closest grid.
